Rear drum
fhurricane1000
New Member
7:38 AM
Can some help me identify this rear drum, and where I can buy a new set. It's 10 inch and made in Canada. It's on my 67 coronet rt w/ power disk brakes. Thank you..
That's not a correct 1967 drum, should be smooth with no fins
10" rear drums for 67 Coronet are readily available just about anywhere. Go to your local auto parts store and they can order them in unless you want to do it on-line through Rock Auto or another source. But.... since they seem to have been swapped out in the past, verify the dimensions of the brake shoe surface with your order.
Thank you for the responses. I know these are not oem style drums, (not finned), but I would like to get ones that are finned if possible, from the same company. The quality is excellent. I have had them on my car since the early 80's. I have one of the original drums that came on the car, and these are nicer. Thanks..
That's very specific and probably unobtainable new. Sorry, I don't know of any supplier. Good luck.
#41 you are correct the drums are no longer available. They were made in Canada. I was able to finally get the one drum off that was stuck without any damage. I will have the turned when I am ready. Thank you.
