Loose Quarter Window
Myasylum
8:46 PM
Hello,
I have noticed the rear quarter window is quite loose, however it still functions as it should. Is there a simple bolt that can tighten this down, or like everything else, nothing is simple.
I noticed the passenger side door window rattles a bit too, hopefully a simple fix.
Thanks!
Lol, that is a simple fix!
I did notice I can grab onto it, and move it around an 1" in any direction.
Im not even sure how the window is held into place?
Hello,
Thanks!
The window is bolted to the window mechanism by 2 bolts they have steel washes with paper washes that go against the glass and also have a rubber grommet in the center.maybe one of the 2 bolts have shaken loose pretty easy fix but rear seat & door card has to come off then roll down the window to a point were you can see both bolts & simply tighten up the bolts but not too tight.This is on a 69 charger so I'd say most B body's would be similar
This is the most difficult repair in a 66-67 Charger. What kind of car do you have?
It's a 1972 Satellite.
I think the answer to everything should be, "Get a Service Manual" then delete all forums because it would make them obsolete.
Internet? smh... old school technology. They have books for that!
And some of the harder parts to find especially if you need one of the roller brackets.
Yea, that bolt is super tight, but looks like it could use a washer or 10.
Close! It should be, get a manual, be familiar with what you are working on, then ask questions about what you can't figure out
The other side has a spring on the inside of the washer that holds it right. Pretty interesting.
Yes I'll find a manual.
