Two Questions
1) It has been a couple years since I removed dash and have totally forgotten where the fuse box mounts, dumb and probably obvious but help an old guy out anyway.
2) my dash has the map light with switch. I have a new one. Pic attached. On the diagram (pic attached) the wiring from the map light -pink goes to fuse block. Yellow goes to the panel light switch via the rh door switch. That wire is cut off and has no connections. How do I connect the wires going through the door switch that has a single pole connection?
TIA
TIA
