Eric F
- 10:20 PM
- Jan 22, 2023
- Atascadero California
70 Road Runner 383 bored .060 9.3 compression 440 source heads, Mopar 272 cam( 224@ .050 .455 on cam sheet(mopar catalog shows 231@ .050) )
DP4B intake stock high performance manifolds. 2 1/2 exhaust. Current carb Street Demon 750( thermoquad looking one) 1 no mater what I do I can not get the air door adjusted right it’s either too tight and slow secondary opening or opens too quick and bogs. And the spark plugs show at cruise speeds it on the rich side. Outer ring is black. The center porcelain is tan to chocolate color. I bought the jet/rod kit. Guess what the smallest primary jet in the kit is the same one as what that carb comes with. Same with the secondary jet. Same with jet needles. That was a useless waste of money. My daughter was driving behind me and said when I get on it she sees a big puff of black smoke. I’m thinking the goggle valve as Demon calls it.( it’s like a 3 bbl ) is too much for my combination. Not enough air flow to take full advantage of it.
I’m considering an Edelbrock AVS2 650 but unsure .
