FOUND Rear wheel well vapor separator shields
GTX 440
1:42 PM
Farwell, Michigan
Feedback: +3 / =0 / -0
Looking for the shields that go in front and below the vapor separator tank located in the Drivers side rear wheel well on a 1971/1972 Plymouth Satellite/Roadrunner or GTX.
I believe I have what you need. The ones I have are from my '72 Charger. Tomorrow, I will compare your picture to what I have. I was just cleaning/ organizing my shed today and moved all of the pieces in the picture. My name is Rick and I'm in Patchogue, NY 11772 I just checked, and I have all of the pieces. I guess I would have to spot weld drill the 2 brackets off. I'm sure that I can rustle up all of the hardware. The car had under coating sprayed in the area so the pieces are in decent shape. I'll try to send you some pics:
Thanks Rick. If you could send some pics that would be great. I don't think they are spot welded on. The front shield bolts on with the vapor separator tank. Not sure about the lower though.
Rick,
I just sent you a PM.
