Rear Drum Wheel Stud Installation Help
Tyron68
6:55 PM
Kellyville
I am in the process of rebuilding my rear drums (69 Charger with 10” drums) and thought this would be a good time to replace my left handed thread wheel studs. How do I do this?The originals were easy to pop out. Do I have to remove the rear axles to have these pressed on or something or is there an easier way?
When I put front disc brakes on, all I did was put the wheel studs in and tighten them using the lug nuts.
Make damn sure you have the correct stud/knurl diameter. Then they sould just pull in from the back with an appropriate grade 8 nut and an impact gun if you have one. Use the wrong size knurl and you'll fight this for the rest of your days.
There’s a slight different but the diameter is the same (old on right). I think the brand is Dorman. It is really hard to see where the slots line up.
Some will say not to pull them thru using nuts. I did mine that way with no issues.
If you have front drums, and plan to stay with them, they are also doable, but they are not only pressed into the hub & drum, but they are swedged.
They have to be pressed out...and you will need support from behind, like a deep well socket, for the stud to drop into once pressed. When the swedging breaks free, expect a loud 'pop'. Installing new studs will be just like you did the rear. Bonus is once complete, the front drum will now be removable just like the rear...without removing wheel bearing.
Tha
Fortunately I do not have front drums so this would only be for the rear.
Getting them lined up seems a little sketch since you can’t really see the Knurl of the stud?
