- 11:26 AM
- Aug 18, 2024
- Virginia Chesapeake Bay
I have a 1974 RR but the 440 is not original. I'm searching for the electrical temperature sending unit that operates the stock gauge in the rallye cluster. I also have an aftermarket mechanical gauge installed under the dash. That sending unit is easy to find as it is in the standard location on top of the water pump. I have searched all around the water pump and can not find the electrical one. I am replacing the aftermarket mechanical gauge with an electric gauge and would like to run both wires to the same sending unit, provided one sending unit will work for both gauges. The service manual just says to remove the unit it does not show or say where it is.
