Who fabricates the best aluminum oil pans? Stefs or Canton?
fullmetaljacket
3:52 PM
Brooklyn, New York
Looking into an all aluminum oil pan for my next engine refreshen. Who fabs a custom oil pan the best? Canton? Stef's? Charlies? Real world experiences please.
Mine is a steel Moroso unit with a slight modified semi elliptical rear side wall to clear the center link.
Stef's or Charlie's over Canton or Moroso. Canton and Moroso's aluminum pans are better quality being built from scratch.
However, their steel pans are horrible being made out of cheap Chinese cores, just adding their sumps and traps doors, which seem to be welded up all over within the sump area.
The bolt holes are always off on the pan rails also. Usually, drilling each hole up one side gives you enough clearance to get it aligned and bolted up. We use hundreds every year and there almost never a drop on and bolt on pan.
I have always been happy with Milodon pans and products.
However, their steel pans are horrible being made out of cheap Chinese cores, just adding their sumps and traps doors, which seem to be welded up all over within the summer area.
Thank you.
Yeah, I wanna have them fabricate the exact one that I have now, which is steel, but in aluminum.
After you price one you may be making a template. Then cutting and bending it yourself. Then you only need a good aluminum welder. We are thinking about running some flanges and replicating existing pans for our own use.
Moroso Street/Strip Oil Pans 20763​
5 out of 5 stars ( 1 )
Part Number: MOR-20763
  • Moroso 20763 - Moroso Street/Strip Oil Pans
$868.99
Oil Pan, 361-440 & 426 Hemi, Center Sump, Aluminum, -12AN External P/U Engine Application; 361-440 and 426 Street Hemi Fits; Chrysler B & E Body
See More Specifications | Check the Fit
Estimated Ship Date: Nov 1, 2024
$868.99
Add To Cart
Back to Results
Overview
Applications
Q&A
Reviews
Will be special ordered for you
Estimated Ship Date: Nov 1, 2024Would you rather pick it up? Select Location
  • Free Shipping
Summit Racing Equipment Protection Plan Shield
Select a plan and add to cart. Learn More
1 Year:$83.992 Years:$192.993 Years:$246.99Decline Offer
Add To Cart
Overview
Brand:
Moroso
Manufacturer's Part Number:
20763
Part Type:
Oil Pans
Product Line:
Summit Racing Part Number:
MOR-20763
UPC:
084663207631
Sump Style:
Wet
Oil Pan Style:
Street/Strip
Rear Main Seal Style:
2-piece
Sump Location:
Center
Dipstick Location:
Passenger side
Oil Pan Capacity:
7.00 quarts
Stroker Clearanced:
Yes
Maximum Stroke with OE Rod:
4.500 in.
Dipstick Provision:
Yes
Dipstick Included:
No
Oil Pan Depth (in.):
5.500
Oil Pan Material:
Aluminum
Oil Pan Color:
Natural
Baffled:
Yes
Kicked Out:
Yes
Kickout Position:
Driver and passenger side
Windage Tray Included:
No
Pickup Included:
No
Oil Pump Included:
No
Oil Pump Driveshaft Included:
No
Crank Scraper Included:
No
Gaskets Included:
No
Hardware Included:
No
Quantity:
Sold individually.
Designed for street performance machines that see occasional strip use, these Moroso oil pans are modified with deep or kicked-out sumps for increased capacity and oil control under hard acceleration. With a simple bolt-on installation into most production chassis, these Moroso street/strip oil pans are perfect for the weekend warrior.
Warranty
does fit 1963 K frames with the lip trimmed.
Believe you me Doug. I have thought of taking a fab jab at making my own pan, but time is limited even though I have an excellent Military certified tip-mig-arc welder friend.
$868.99
$868.99
Add To Cart
Back to Results
Overview
Applications
Q&A
Reviews
  • Free Shipping
Add To Cart
Overview
Brand:
Moroso
20763
Part Type:
Oil Pans
Product Line:
MOR-20763
UPC:
084663207631
Sump Style:
Wet
Oil Pan Style:
Street/Strip
2-piece
Sump Location:
Center
Dipstick Location:
Passenger side
Oil Pan Capacity:
7.00 quarts
Stroker Clearanced:
Yes
4.500 in.
Dipstick Provision:
Yes
Dipstick Included:
No
5.500
Oil Pan Material:
Aluminum
Oil Pan Color:
Natural
Baffled:
Yes
Kicked Out:
Yes
Kickout Position:
No
Pickup Included:
No
Oil Pump Included:
No
No
No
Gaskets Included:
No
Hardware Included:
No
Quantity:
Sold individually.
Warranty
Stg3 This pan by Moroso though looking very sturdy and well welded, the kick outs will interfere with my custom headers. Thank you though.
Here's an of image of the pans oil well rear wall. It's a simple 971 Moroso 6 quart pan modified with a semi-ellipes rear wall to clear the center link movement. This is what I was thinking of having fabricated in aluminum.
I just picked up the same oil pan with a 1/2" Hemi pick up tube for $50.00 for both at a swap meet recently. He made me buy it for that...
Every crank scraper or pan I've used has the holes off. Annoying, but no real problem.
Funny thing is that both Stef's and Canton are relatively close to me. I can take a short drive and see their operations first hand and also pick up an existing pan that I could modify to my specifications. I have no scraper or trap doors in my steel pan, just a baffle and a center 1/2 NPT pick up.
The morose pan above I have on my 69 charger with a hemi 2nd gen . The drag link hits pan when turned all the way right and left haven’t figured out what I need to do to fix it FYI
Check the photo of what I did to my Moroso pan. It clears very well. That is why I would want a replica strictly following the modifications that I did in aluminum if anything. Not in a hurry though.
