69hemibeep
I read years ago and it may have been a chevy service manual but it will give you an idea that (normal) operating range of a factory gauge is 195-220. Climate, hills and A/C will make them run warmer.
My 22 uses factory 7 blade no clutch and shroud and still doing good but I had shop add another row (3 ) up from 2Also in Florida here, so I'll have the stock fan shroud, wetter water, cooler running water pump, still trying to figure out radiators but would like stay with a stock appearing 22" (feel free to recommend based on your experiences), and has a 50 year old flex fan. should I go back to a stock fan with fan clutch? I'll also be adding Classic Air which it doesn't have now.
Thanks,
Jim
Unfortunately stock rad was swapped out for aftermarket - highly original car. Is that the stock shroud can you tell?If you're concerned, Perhaps get the radiator boiled out and rodded, to restore it to original efficiency. A common job we had back in the garage, once done, vehicle back to operating as usual. If not already equipped, I'd recommend a shroud.
Confirmed 16# now.Yes it should. My recommendation is 13# for cap. Little less pressure is good for the hoses.
Did you have the 3rd row added recently? If so, may I ask what you paid? I'd love to keep the original top & bottom tanks as long as it will cool sufficiently without going aftermarket like Glen Ray Radiators or U.S. Radiators which is what I'm looking at now. ThxMy 22 uses factory 7 blade no clutch and shroud and still doing good but I had shop add another row (3 ) up from 2
Was many years ago but did reuse my tanks at local shop hereDid you have the 3rd row added recently? If so, may I ask what you paid? I'd love to keep the original top & bottom tanks as long as it will cool sufficiently without going aftermarket like Glen Ray Radiators or U.S. Radiators which is what I'm looking at now. Thx
Glen-ray for radiator, throw out the flex fan, use factory fan & clutch.Also in Florida here, so I'll have the stock fan shroud, wetter water, cooler running water pump, still trying to figure out radiators but would like stay with a stock appearing 22" (feel free to recommend based on your experiences), and has a 50 year old flex fan. should I go back to a stock fan with fan clutch? I'll also be adding Classic Air which it doesn't have now.
Not the stock fan or shroud. It is better than none but IMO a thermo clutch 7 blade fan would be an improvement even with that shroud.Unfortunately stock rad was swapped out for aftermarket - highly original car. Is that the stock shroud can you tell?
Thanks. Will go through Glen Ray at some point. Knowing this helps.IMHO, not original, doesn’t look quite deep enough.
Thanks for confirming. Have intentions to get Glen-ray to build one. Ultimately that’s the longer term solution I believe. Appreciate you weighing in.Not the stock fan or shroud. It is better than none but IMO a thermo clutch 7 blade fan would be an improvement even with that shroud.
That looks like original fan and shroud to me. Looks like my 70 GTX 440. That is a factory 7 blade fan without a clutch just like mine.Unfortunately stock rad was swapped out for aftermarket - highly original car. Is that the stock shroud can you tell?
First roadrunner and was a little surprised the shroud was so shallow?Im sure there is one but not sure of the engineering reasoning?That looks like original fan and shroud to me. Looks like my 70 GTX 440. That is a factory 7 blade fan without a clutch just like mine.
I run 180 or 190 stats in every car. They run just above them, but hot day in traffic they may go to 220. Still don't puke...
When we did my motor as mentioned it was 30 over and 11.5 cr prior a stock motor and 2 core was great but the new configuration caused temp rise hence the factory rad 2 row getting recored to 3 and back to 180 temps. Food for thoughtFirst roadrunner and was a little surprised the shroud was so shallow?Im sure there is one but not sure of the engineering reasoning?
I think the 16# cap is ok and will replace the thermostat for 180 just so I’m more aware how hot I should expect to run.
A new car to me. Motor professionally rebuilt 10 years ago 60 over and post rebuild, but before the aftermarket rad, had reportedly a history of overheating. You can correct my thinking but if necessary I’d sacrifice just a wee performance for longevity at this point.
Sensable?
I certainly wouldn't be complaining about 205! Water boils at 212 with no pressure cap.
And every pound of pressure raises the boiling point 3°. A 15# cap raises that 212° to 257° at sea level. The pressure cap, altitude, and coolant mix adjusts those temps but not by much.
I don't like over 210-215 F. Sort of a warning at those temps, and I will pull over and stop if it get to 230 F.
Good data. Thank you!![]()
For an example, even if you only have 1/3 of the coolant with anti-freeze and are using a 16 psi radiator cap, you won't see boiling until 260 degrees.
"I saw 200 on my Factory gauge. I'm overheating!"I see these posts frequently and sort of shake my head....
You may not realize that the factory gauges were not necessarily built with a NASA level of accuracy.
Even so, look at the following chart:
I read from dudes getting scared at 220 degrees. PFFftttt !
Relax...there are far bigger things to worry about.
If you aren't puking coolant out all over the street, you're not overheating.I do find these temp conversations - which are very common - a touch interesting. In this post and others, folks keep referring to the boiling point as the measure of "overheating". That implies once it boils over, you've overheated despite the actual temperature (i.e., related to pressure, fluid types and mix, etc.). This seems a bit counterintuitive.I see these posts frequently and sort of shake my head....
