Correct fuel tank sending unit for ‘73 Charger with 440
i am replacing my fuel sending unit on my 1973 Charger. Does the 1/4" tube get blocked off or should I put a hose on it for venting?
Is it an original 440 car? If so it connects to the 1/4" return line from the fuel separator. If not a 440 car either add the return line, (helps with vapor lock). Or like Nacho said block it.
