BSB67
Here is the problem, we don’t know what you know, and don’t know.My intent, first and foremost is to get educated here, thus as a novice, please bear with me. I have a '73 stock 440 HP. I want to leave it stock in external appearance but would like to get more power out of it, similar to a stock '71 440, thus without going to a different head, my most effective options would be pistons and cam (I think). I am thinking about replacing the thermo-quad with a Holley Sniper EFI and eventually going to an overdive automatic trans. My intent is to have a great highway crusier not a drag car and I could probably just rebuild the engine in stock '73 form and get that. However, it is a 440 and without getting to radical I'd like to get more out of it than the stock '73 version offered. I know they changed how they rated horsepower starting in 1972 thus I don't know how far apart a '71 vs. '73 are if they rated horsepower the same way on both engines. I do know the compression ratio is different amoung other things. Thanks for any feedback.
It’s not clear to me if you know what it means to change pistons. Some experienced folks can probably do a piston swap on the cheap in certain conditions, but that’s not you.
You take your motor to a shop and ask for new pistons you’ll probably have a $6000 bill when it’s all said and done, you’ll still have junk heads, and little performance improvement, IMO.
Conversely, the right set of well prepared heads will cost half as much and give a noticeable performance boost.
Let’s start with: What is your budget?
