SOLD 383/440 4 BBL/Mopar Fresh Air Cleaner Metal Base For Dodge And Plymouth 70 71
Duran75
9:46 AM
Phoenix AZ
Feedback: 3 / 0 / 0
New 383/440 4 BBL/Mopar Fresh Air Cleaner Metal Base For Dodge And Plymouth 70 71. Purchase from a local swap meet.
Asking $300.00. Plus shipping
I think the 383 & 440 versions are slightly different. If you put the base on a flat surface & the outer front edge of the air cleaner sets flat on the surface too, it’s for a 440. If the outer front edge sets about 1” off the flat surface, it’s for a 383
440…
Can you use the large oval filter (like a 6 pac has) with this base?
Yes you are correct but 440 and 340 use the same base,383 and 400 are the same. Reason being for differences is low deck vs raised deck and 440/340 Thise are scarce
No…. Round filter
Then try one, oval will lay in the but what are you gonna use to hold the lid on? A hole drilled in the middle of the Hemi or 6 pack lid?
This is how it looks with the round lid. I’m not selling the lid, just the base.
I'd argue this point for no other reason than what I have was advertised as a 383 unit when I purchased it. As you can see, the front sits flat. FWIW - doesn't fit under my A12 hood with this intake.
Hello, I sent you another PM as I want to buy this 440 fresh air single carb base plate you have listed. And can send payment tomorrow. Ken
