Found a good paint product...
skicker
3:33 AM
Cumberland, Maryland
I decided my open trailer after 15 years was looking a little rough...
Cleaned and sanded what was needed and applied some new paint...
It is an enamel that can be used out of the can for a brush or roller...
Product was available at Sherwin Williams and was called Sher Kem...
Liked it so well I did the front of my box trailer too...
I rolled everything and then back brushed it and it turned out pretty good...
Looks pretty good :thumbsup:
flowed out well for a roller & brush
Couple of questions: did you have to use a primer or just apply directly to the metal? Also I see you have a gallon can, did that can alone do your trailer or did it take a couple of gallons? Thank you
Sherwin Williams makes a wide range of great products... I used 5 gallon buckets of their industrial paints on my trailers decades ago and it worked great.
The big names do a lot of advertising but that doesn't equate to being the best.
No primer...
I rolled it straight from the can and then back brushed it to get it smoothed out...
1 gallon is what I bought as it only comes in gallons...
My open trailer used a little more than 1/2 gallon...
I have an 18' solid deck so a trailer with just ramp surfaces would use even less...
After finishing both trailers I still have about 1/4 gallon left...
