you tried 0.090 - 0.150 ,,, what was the original shim thickness when you pulled the diff apart ,, in a 742 case should have been in the 0. 86 - 0.095 range ,, depending on the case / gear ,, if say the original shim was 0.090 you should have taken out 0.003 like i stated in my previous post and tried a 0.087 shim to move the pattern up on the tooth on the drive side keep doing this until the drive pattern is at its best ,, centered heel to toe on the tooth ,, the coast pattern will follow . you have to move in increments of 0.003 to see a pattern change and on the 8-3/4 if you have too much toe (inside of the tooth ) which you have remove shim thickness ,, too much heel ( outside of the tooth ) add thickness ,, again in 0.003 increments and run a pattern check with each change. you have to work at it but if these were truly never run new gears the pattern should be close to what is in the pic i posted.
