FOUND 68-70 coronet 4dr front stainless window trim.
Rsisk108
7:54 PM
Birmingham, AL
Feedback: 1 / 0 / 0
3 pieces each side. Runs around the outer door frame around glass. Thanks
I have a 68 Coronet 4 door parts car but it doesn't have that trim.
Need anything else ?
I might have it from a 68 Coronet 4 door. Can you send some pictures so I can verify.
Here’s a couple. The top piece is the worst. If I could get it I can live with the other 2. Thanks
I don't have the door trim but I do have the B pillar stainless pieces.
I have a pair of front doors from a 70 Coronet wagon that should have the trim. I'll check my barn on the weekend. How is the trim attached? Screws or just crimped on?
Crimped on. Fairly easy to remove once you get started. At least mine was. Do you happen to have the rear wagon doors? I need them also just thought too far of shot here. Thanks
Are 4-door rear doors the same as the rear doors on a wagon? These doors are in my yard. The front doors have the trim you are looking for.
The front are the same for sure. I think the rears may be a little different. However I’m not 100% on that.
Wagon rear doors are different in that area.
Hi. I dug the doors out of my barn. I had the front and rear 70 coronet wagon doors. I went ahead and took the trim off because I wanted to make sure I could pop them off without damaging them. They are all in decent shape. All have some light scratches that should polish out but no deep scratches or dents. One piece has a bit of a twist to it but is not bent. Hard to take good photos of stainless trim.
Let me know if you are interested. I'm open to whatever you think is a fair price.
Don't know if the same, but my 67 coronet 4 door parts car has a complete set. From the pics looks the same. Pm me if your interested. I'll give them to you if they will work.
Thanks for all the replies! Trying to work a deal with 70netrt as he has the exact parts I’m needing.
