Suspension rebuild 73 Road Runnner
Rangepony
3:41 AM
Greensboro NC
Getting ready to do an all out bushing etc rebuild on my 73 Road Runner.....does anyone sell a complete kit? I see partials but not a full kit.....also...are the rear sway bar bushings the same as the front?
Not sure I want poly but am not totally against it.....I would like new shocks as well.....trying to stay stock (or close to it)
Car has factory 340 with 57,000 miles...everything is ready to be replaced due mostly age....
Thanks for your help
For a factory look, go with black polyurethane bushings for the sway bar (at least)
Did you check with PST,we get 10%
Energy suspension has front sway bar bushings, measure your bar before ordering there are two sizes. No one makes a kit for the rear. I found NOS on eBay for the square ones, bought energy suspension end link bushings and used 4 of those. And the frame bushings I used front bar bushings of the same size as the bar.
PST kits are good.
They used to offer a "complete" kit and a "basic" kit.
I saved a few bucks by getting the basic kit and buying the rest by the piece.
Not sure if that's still the way to go.
You want poly-GRAPHITE bushings, not polyurethane.
...or they will squeak.
Some (like UCA, IIRC) are not available in poly-G.
I'd use rubber there, as those are prone to squeak anyway.
