Wipers not returning to Park Mode
bob32268
12:44 PM
Johnstown, Pa.
I had to have my wipers on recently (1st time in over 5 years). Turned them off when I got the car back in the garage and this is as far as the wipers would recede (see pic). How do I get them to go back down into park position ?
tks,
Bob32268
Do they sweep lower when running??? If so your park switch is set to the wrong location. If they don't sweep lower, you just need to pop them off and reinstall.
No, they don't sweep lower, so removing them and re-positioning them sounds like the way to go.
Tks much,
Bob32268
Reminds me.. I need to get two people to hold the wipers up on my Superbird and to make sure mine don't sweep lower than the trim! Thank you !
Apparently they park, just not low enough. Just installed wrong...
They did park correctly the last time I used them (prox 2017) and now last week they park too high.... WTF?
Tks,
Bob32268
To help locate the correct position of the wiper arms before installing, tape some
toothpicks and run the motor and see if they go past the trim
Tks,
Bob32268
You stated that they didn't sweep any lower than your posted picture, so that makes no sense.
The picture is how they worked and parked last week, they seemed to work Ok back in 2017. Now, since then I have done work behind the dash bezel, new switch (roller) that dims the interior lights, not sure of what else. Maybe something with the wiring to wiper switch ?
Tks,
bob32268
Check the wires at the motor. Key on engine off. Wipers OFF. One wire should have power.
tks,
Bob32268
Member @Topher will be able to help in this case.
