70 Road Runner / GTX rear window headliner Hook plates & fasteners.
Fabman
12:25 AM
East Coast
Starting my headliner install in a 70 Road Runner. I had to order the fasteners that hold the rear window hooks plates to the inner roof structure (Pics attached) but since I took this apart about 18 years ago - I am having a metal block (I mean I've forgotten) exactly how these fasteners hold this hook plate in place. Anyone can give me some direction here on how these work? Please see attached pics - One pic is of when I took the hook plates off - the other pic is of the new fasteners.
I believe you install and twist them,I pulled mine off of my charger. Someone will reply on it. @eldubb440 might know.
THATS how I got the old ones off - but the new ones don't fit the holes ...the small ends are too small for the holes in the roof structure OR the hook plates
You can just line them up with the holes for the old retainers and use self-tapping screws for sheet metal... It really doesn't matter cuz once the headliner is installed you can't see the self-tapping screws anyway. So what's the difference? Just my two cents!
AGREED ! THATS Exactly what my plan is - but I thought ID inquire anyway. Thanks for the reply
So I had the same issue. What I discovered is put the clips in the hole and then squeeze the 2 tabs that face you with a painful pliers to expand them
Please elaborate on this - I do not get what your talking about..
Ok - Thats a possibility ...Ill give it a shot - see if it expands enough. Thanks!
Now that the holidays are over its time to get back on the RR. The info you guys provided worked well for the rear window "Grab Plates" ...NOW my question is - What is / are the finish trim fixtures that go around these grip plates that finish off the rear of the headliner?. As I've stated before - this car was taken apart over 20 years ago...I took a lot of photos on disassembly - but you never take enough.....and I dont have the details for this area. Looking thru my parts on the shelves - I don't even see parts to finish this area. Pics would be great ! Thanks again.....
