Braking test results
HEMIB
2:23 PM
Australia
Did Plymouth or Dodge ever do a braking test on a 72 Road runner ,factory disk front drum rear .i am trying to find test results to compare with what i have now
I should have braking results that came new in my packet with my 72 in the day. Can check and post pics tomorrow if I have what your looking for?
Yes, braking performance was supplied with the new car paraphernalia when purchased.
Yes, the results were not likely considered "good" these days.
I tried that once. If you slam on the brakes, I'm not sure which wheels will lock up first or which ditch you will go in. Your results may vary.
Don't forget, brakes stop the wheels, tires stop the car.
Meaning, unless you have original as tested tires on the car, a comparison today will indicate little.
