Where to get Manifold Vacuum for Air Grabber on a 6 pack intake ?
jh23job
6:48 AM
Pingree Grove IL
70 Road Runner, Not sure where the correct place is to connect the vacuum line from the canister for the Air Grabber to the Manifold Vacuum Port on a 6 pack, when I don't see one anywhere, or on the Carburetors that isn't already being used.
Any help would be greatly appreciated.
Thank you
If I recall correctly, at the rear of the intake manifold, below the rear carb, is a place for the vacuum fitting. This fitting may have one or more nipples, depending on your options. This supplies the vacuum to the air grabber reservoir.
@Rishi, that's exactly what I thought, and there's absolutely nothing there, not even a plug where a nipple used to be. Bizarre.....
Any other suggestions ?
Really? It should be on the back of the intake about 3” below the base of the rear carburetor
I will double check when I get to my shop..
That's where I thought it would be as well..
I appreciate you clarifying that it's supposed to be there, so it must be. I'll put on my glasses this time..lol
You can see the port here without fitting.
Found it !! Thank you so much
It sure helps when I use a step stool and a flashlight along with my glasses
You guys are amazing !! Thank you again
Yes, that port is where we tapped into for my buddies air grabber on his 70 R.R.
You can get a vacuum fitting for that port with one, two, or three outlets, ( along with a power booster outlet ) depending on specific requirements.
