69 Charger sway bar bushings and end links.
Grizzlys Garage
7:53 PM
Southern Illinois
Where do I get sway bar bushings and end links for my '69 Charger R/T ?.
I think I read somewhere that you have to cut and reweld the brackets to install the bushings.
If so, how do I keep from melting the bushings when welding ?
I just ordered a set on Rockauto. Nothing fancy. Moogs. They’re $4.50
If they are the triangular ones similair to a 69 RR, a couple of pair of channel locks will get the job done, without cutting/welding the bracket.
This, slide them down to the end of the bar, it narrows slightly by the eye for the end links.
I put the ford ball joint end links on a 69 b body and they work awesome. Total drop in like it was made for it! I got moog off rock auto. Plenty of posts with the numbers I don’t have handy. They weren’t much. 16 bucks I think.
