Rear sway bar for 73, 74 Runner?
ALbabymopar
4:15 PM
Pennsylvania
Hi Mopar members, Al here ....so I'm looking for replacement rear sway bar bushings for a factory set up. One is square and the other looks like a standard front sway bar bushing. It seems impossible to find either. Anyone have an idea where these could be had?...kinda reaching my wits end. Much appreciated to all of you! Let know your thoughts, Thank you!
I found a pair of NOS for the square ones on ebay, and used and Energy Suspension front of the same diameter for the frame mount ones. Those bolted right up. I also used standard Energy Suspension end link bushings for the links. When searching for the square ones look for later b-bodies like Cordoba as well.
A quick google of the part number for the square ones, (#2269709) shows Arizona Parts has 14 in stock. Parts
Fantastic, I like the energy suspension piece and will get that. I looked at their site, but didn't find that under direct application (of 71 to 74 b body) and I'm sure there are many applications for this size, but out of curiosity do you know the application? (future reference). I will also Chase down Arizona, truly appreciate your experience and insight!!
It is a one size fits most part so there is no specific application. I just searched based on my bar size, and the bracket to fit my frame.
Pics of the parts mentioned above installed.
I used several different kits to do my front and rear rebuild on my 73 Road Runner...I'm not sure if it was the most efficient but I got everything with some leftover stuff.....Energy components, Northern Auto Direct and Moog
