FOUND clutch 18 inch-18.5 fan blade
gtxrt
10:34 AM
central ny
Feedback: 4 / 0 / 0
looking for 18-18.5 clutch fan blade with or without the clutch.
I have a 7 blade fan only that I'm pretty sure is 18".
I'll pm with pictures and see if you like it.
Question- are you running a shroud ? If so you might want the proper one for your car. JMO
has a shroud. I have a fixed 18.5 on there now 7 blade. what one is the right one ?
I have an extra 2863216 fan, 18.5 Diameter, 7 blade and might have a used thermal clutch.
2265034 4 blade 18 in steel blades with heater
2585375 7 blade 18 in aluminum blades with CAP
2585376 7 blade 18 in aluminum blades with A/C
2843225 7 blade 18 in with heater
Still available? Price? Part number stamped on blades? Thx
Yes, but there are no numbers stamped on the blades. Must have been ink stamped originally and painted over by someone other than me. I sold a numbers stamped fan and this one was identical in every way to that one. $60 + shipping for the fan.
I may have found one but will let you know if not. Thanks!
