Oh My!
Here is what I have. late 440 block, 30 over, Icon IC968 flat tops that are .022 above the deck. My original plan was to run a set of redone 452 iron heads. Compression with an .039 gasket and assuming 88cc's for the heads have me at 10.25 compression.
So I feel this is too high for iron heads so started looking at aluminum. A Stealth is 80cc's and Sidewinders are 84cc's. If I run a .051 gasket this gives me .029 for a quench area. Too little? Quench area on the 452's is.097 with .039 gaskets. Edlbrock has an 88cc open chamber.
Todd Marsh can assemble me a head to match the cam I choose and he is close by so there is that. They are angle plug heads but from what I have read not a big deal with manifolds.
This is a 74 Charger, Automatic 2300-2500 11" converter. 3.23 gears. HP exhaust manifolds. Performer intake with a 850 Thermoquard was the plan. I am looking for cruising drivability and need vacumme for AC and power brakes.
Cams. I was looking at the Crower 271HDP or the 267HDP. The 271 has very simular specs to the Voodoo 702 that I have in my 71 but that is a 4-speed with 3.55 gears, I like it. It has plenty of vacuume and a nice idle.
I called Crower and the tech was pushing the 277H over the above grinds. This is very much like the Summit 6400 and I have one of those on the shelf, but it seems small but would have a ton of touque.
I would be open to a gear change if needed but thoughts on if either the Crower 271HDP or 267HDP will work with the 3.23's?
Yeah I know I am all over the place but I can change most anything for this short block at this point in the build.
