seat belt mounting point - driver side tunnel
subforry
11:44 AM
Hermosa Beach CA
Hi all,
I installed sound deading mat and new carpet in my '66. I found the seat belt mounting points. The problem is the driver's inside (tunnel) mount. It's the L shaped bracket, but the bolt does not catch on any threads. I tried a longer bold, no different. Is there a capture nut or maybe loose nut on the inside of the L bracket? I think I have the hole in the right spot because it passes through the rear center console.
Also, do these cars have a belt mounting point in the roof for 3 point belts?
Thank.
Hi all,
Thank.
They did not have any attachment points on the roof. Optional shoulder belts in 67 came from the inside rear seat belt anchor over the front seat. I have never seen one in person and don’t know what the front belt would look like.
The seat bolt should not be going through the console l bracket. If you get under the car you will see where the seatbelt nuts are.
Hi all,
Thank.
You made me go routing around in my racecar, and sure enough, I hadn't hacked it out. It has a large nut that's fused to the bracket. Yours must be broken off
And ya that appears to be a smoke laying there
You made me go routing around in my racecar, and sure enough, I hadn't hacked it out. It has a large nut that's fused to the bracket. Yours must be broken offView attachment 1789567
I learned something today. Thought it bolted to the tunnel, now I have to check mine.
Yours won't have it because the 67 console is short. My 67 with a 66 console could use it. My seat belt just goes through the hole to the tunnel.
It's just 1 of those 200? Differences between a 66 and 7
I think a 66 may have both belt mounts.
Yep , I put the race belts in the tunnel hole. The other one is straight out to my finger
Sorry my flash died power low
