padam
Also I’m pretty clumsy.That #'s 833 has 158,000 miles on it, never been taken apart.
I usually started around 17-18 and never went below 15, it wasn't a huge improvement but it did help. The car was set up more for handling so track launches were hit and miss with the four speed.How much did lowering tire pressure help you out? I haven't tried it out, because I heard that it didn't do too much on street tires and is more of a drag radial or slick thing. Where would you start out for pressure if that's the case also?
What do you mean by preload? Like holding to where it feels like it wants to pop out of the gate, and then slamming it home when you pop the clutch?Talking stock style sliders and hubs. You can shift just about any manual without the clutch. If and a big if. You let up on the throttle and move the lever slowly shifting like my Grandma. On all out acceleration? Not a chance. Mines had all the sliders hand filed. Shifts very easily. However under heavy throttle you can pull on the lever as hard as you want. It won't move. That's the secret to fast shifting. Preload the shift lever. When you tap the clutch it'll come out of gear. By the time the lever starts moving the pedal can be released.
Yes try to pull hard on the lever during hard accelleration. It won't pull of gear unless you lift the throttle or hit the clutch.What do you mean by preload? Like holding to where it feels like it wants to pop out of the gate, and then slamming it home when you pop the clutch?
It sounds like you need to learn how to drive this car without breaking it before you get too caught up in making it faster. You’ve smoked a 727, broken a diff, and several motor mounts. I don’t know if this car will live if you don’t learn how to keep it together. Just my thoughts.
Travis..
The 727 i smoked was on its way out... it didn't pull at all and was slipping. the motor mounts I'm honestly not sure if it's how I installed them because the first set lasted like 5 months then the second set was shitty autozone parts that lasted one day, then the poly mounts lasted like 2 months.It sounds like you need to learn how to drive this car without breaking it before you get too caught up in making it faster. You’ve smoked a 727, broken a diff, and several motor mounts. I don’t know if this car will live if you don’t learn how to keep it together. Just my thoughts.
Travis..
Yeah I don't get why 7k is that hard of a push for redline as it's a fully forged 71 340 with upgraded roller valvetrain and better flowing heads, exhaust, intake and better fueling system so it doesn't go lean. It also has a 8 qt oil pan so lack of oil isn't an issueI used to power shift mine at the track with no issues, my old cam started making power at 3500 and I shifted at 7000 rpm and it was still pulling, but with the stock bottom end I was going over that.
Also explain, I'm not really trying to make it go faster via mods, I'm exactly trying to do that, learn how to actually drive it properly without damaging it. I can drive it and baby it, I daily a stick shift car I just want to figure out how to drive, shift and get a better et, street tire or slickIt sounds like you need to learn how to drive this car without breaking it before you get too caught up in making it faster. You’ve smoked a 727, broken a diff, and several motor mounts. I don’t know if this car will live if you don’t learn how to keep it together. Just my thoughts.
Travis..
Well, when you say bog I mean when i start spinning and I let off, I don't think it's a car issue but a issue between the wheel and the seat to where I need to learn to feather the throttle and ease on and off and not just let go of the gas pedal like its searing hot. I can break them loose decently well, and I can ride the spinning of my tires out and eventually i gain traction again without it bogging. Ihad the carb tuned with help from a friend since i dont know a god damn thing about carbs outside of a lawnmower. it idles nice and doesn't sound like it pings from leaning out at rpm.I'd suggest getting a tire that will hook and then work on the engine so it works with the combination you have.
If it bogs now..getting traction will make that worse. First thing I would do is get a holley vac secondary or a AVS2, or a thermoquad. You could tune the double pumper, but it will be a struggle, and even when it's dialed in better, the other carbs are easier to tune, and likely faster. I am saying that and I have 5 double pumpers on various cars, none are 4 speeds. On our 340 4 speed we run a thermoquad.
Forgot to say, it also does not give off signs of valve float at rpm, there's still a Lil juice to give when i shiftWell, when you say bog I mean when i start spinning and I let off, I don't think it's a car issue but a issue between the wheel and the seat to where I need to learn to feather the throttle and ease on and off and not just let go of the gas pedal like its searing hot. I can break them loose decently well, and I can ride the spinning of my tires out and eventually i gain traction again without it bogging. Ihad the carb tuned with help from a friend since i dont know a god damn thing about carbs outside of a lawnmower. it idles nice and doesn't sound like it pings from leaning out at rpm.
I don't bog when I step on it from roll at really any rpm or speed, I hear the secondaries kick open and away I go.
My spark plugs are also in good condition, I really doubt it's a carb issue
If you got traction you would know what I am talking about. Breaking traction is helping the double pumper with a 4 speed. A double pumper is going to be a struggle. Just saying. Do research...double pumpers are great carbs. But a high geared 4 speed is a poor fit for one.Well, when you say bog I mean when i start spinning and I let off, I don't think it's a car issue but a issue between the wheel and the seat to where I need to learn to feather the throttle and ease on and off and not just let go of the gas pedal like its searing hot. I can break them loose decently well, and I can ride the spinning of my tires out and eventually i gain traction again without it bogging. Ihad the carb tuned with help from a friend since i dont know a god damn thing about carbs outside of a lawnmower. it idles nice and doesn't sound like it pings from leaning out at rpm.
Okay, so with the thermoquad, would you also recommend going from a single plane to a dual plane like the performer RPM or is the single plane going to match well. Also I'd have to use an adapter to go from square to spread bore.If you got traction you would know what I am talking about. Breaking traction is helping the double pumper with a 4 speed. A double pumper is going to be a struggle. Just saying. Do research...double pumpers are great carbs. But a high geared 4 speed is a poor fit for one.
Will do, still got some time till I can actually break out the car from it's jail in the garage, still dead winter over here. Like the video I posted in an earlier page was from August, I don't know how just from driving stick for another half year and learning more hand to foot coordination will help me improve ET just through quicker shifts.All the rpm air gaps are for a square bore like a holley or a avs. Although, I think a rpm would be .25 second faster in e.t. at the drag strip with 3.55s over what you have. I would start with what you have now. But, get some tires that hook first.
