WTB 1966-69 mopar sway bar brackets
FJ6 v code RR
12:56 AM
Collins Ohio 44826
Feedback: +3 / =0 / -0
Hi look for a set of 1966-69 a/b body sway bar brackets that bolt to the k frame that hold the sway bar. If you have a set please let me know. Thanks.
The triangle ones that hold the frame bushings?
Can you post a pic of the ones you need?
Here are the 68-69 sway bar brackets I need.
FWIW, I also wanted to replace the original sway bar mounts that were lost during a previous restoration. Seems no one is reproducing them and I didn't find anyone willing to sell just the brackets. I ended up buying a complete sway bar with brackets from a member here and used those brackets with my original bar. Trick is finding ones that aren't bent up from hitting curbs. Of course that means I know have an extra sway bar so I plan to use that on another car that didn't come with one along with the aftermarket brackets I replaced. Just a thought...
