Disassembly of 1967 Coronet simulated mag wheel hub cap
profholley
New Member
3:29 AM
Lewisburg, PA
Does anyone have experience with disassembly of the simulated mag wheel hub caps? I need to repair damage to the chrome ring on each hub cap. Also, what are the colors of the painted areas on the hub caps? Thanks for any help.
I suggest that you mark the positioning of the pieces carefully. I believe that they might possibly be balanced somewhat. I took some apart to make nice ones put them together, installed. Then and had a wheel out of balance. Did not mix and match after that. Just my experience. If someone has any further information I would like to receive it. I think those should be the same as Charger.
I've taken mine apart and swapped pieces.
It's pretty easy to do.
I think all the parts are pretty symetrical never worried about balance on the caps.
