Pitfalls of Redrilling Wheel Hubs & Drums For Different Bolt Pattern
Sam69sat
11:51 AM
Earth
Here's my dilema. I bought a set of magnum 500 wheels 15x7 off FB marketplace that were supposedly 4.5 bolt pattern. Well, two of them are 4.5 bolt pattern but the other two are a weird 4.25 bolt pattern. The rims are all brand new but now i'm stuck with these 4.25 bolt spaced rims and i figure it's going to be hard as hell to find someone that needs such a weird wheel. Was wondering if anyone has ever redrilled front or rear rotors AND drums to a different pattern? It looks like it would be possible but would it be safe having extra holes in the drums? Any other things i should be concerned about or reasons it wouldn't work? I know the right thing to do would just get new wheels and i still might do that.
My best guess, you have two Ford rims. I had two Ford rims, used a die grinder enlarged the opening to fit over the front hubs. Drove it to Charger meets in Detroit Jefferson City and elsewhere . Thousands of miles.
You can send the rear axles out to Moser and they can redrill them. Myself cut your loss and dump them. There are places that sell adapters. I hate them.
Its the bolt pattern not the center hole.
Here's a pic of the wheel
Stating the obvious, a 4.25" pattern has weaker mounting (clamping force is the same) capabilities than 4.5", what application are you intending to use the 4.25", and front or rear?
I was thinking fronts might be easiest but backs are also an option. Not set on either one at the moment. I'll try to sell them but don't know who the hell would want a 4.25 pattern. The damn things are brand new and never been mounted.
Mopar small bolt pattern.
No. The small bolt pattern for Mopars is a 4" circle. According to a Google search, some Fords in the past 10 years had the weird 4-1/4" pattern.
In my opinion, modifying your car to fit oddball wheels would be like buying a hat that is too small then having your head surgically altered to fit the hat.
How about modifying the wheels for that oddball (IMO) unilug plug solution from years back?
Are you sure? I though on 5 bolt pattern you measure from the outside of one hole to the center of the opposite hole.
It looked close and logical. I always use a cheap plastic bolt pattern gauge to eliminate guessing.
You could probably easily spend as much or more bastardizing your car to use those wheels than a pair of the proper wheels would cost. And there's no possibility of recouping any of that investment. Just list those for sale and buy the proper ones...
Get the pair of 4.5s you need.
I'll put them up for sale. Thanks for the replies.
If you know someone with cad software just have them make a paper drawing to be sure you state the correct bolt pattern when you list them.
I think they are "A" body GM. Likely Buick Special/Skylark.
Look like 4" pattern to me. Only thing that is worse than getting screwed on Facebook buy is a member doing the same thing. Don't basturd your car , buy the 2 rims you need and sell the 2 you have to the person that wants them. After you determine what they are, I don't think they are 4. 25. I stand corrected, did not know that you measured a bolt pattern that way, guess that I just ballparked the ruler all these years! Looks like 4.25.
I forget what 4.25 fits but yeah it would cost the same to screw up your axles and drums as it would to just buy the right wheels. Advertised them as to what they are and forget about it.
