727 push button trans woes!
Pretty sure I'd have parts. Is the output shaft itself OK? I fixed the same failure for a customer this summer,
What did you end up finding?
Cracked rear pump housing, broken park gear, vaporized governor mechanism. A&A(Rick) hooked me up with everything! Put in spacer to eliminate gov. made plate to replace park mechanism cover. Removed all the mech. Back together - working fine sitting on jack stands, waiting for snow to go and dry roads for test!
Gary
Weremived the governer and thinned the park gear down to 1/4" wide. Also trimmed off part of the snap ring boss in my racecar. Then cut a new groove in the output shaft, so no need for the spacer. If you ever decide you need park. I have a good source of parts.
I have extra park mechanisms and cables. I will be 78 in March, maybe the next guy will park it? LOL!
Gary
Back together on the ground moving forward and backward, all dressed up and nowhere to go. Streets are dry but the snow fell off the roof of the Mopar Pavillion, so no test hit today!
Gary
Gary
Man that turned out to not be too bad at all... i stress about that tailshaft and am keeping a eye out for a spare just in case something happens. And man that car is pretty.. wish mine were a post car :)
Thanks for the compliment - yours looks pretty as well!
Gary
Ah but it's been toned down. Now that it's a dedicated racecar it's not as fast. No more turbo small block. It's lighter and slower. Though it's losing another 100lbs this Winter. Current best is 9.68 vs 9.55. Yours sure is prettier.
That car is so ridiculously clean for a original car, i would kill for that trim..
Lookin good! Still a full sec quicker!!! Lost a couple hundred lbs with the Savoy between myself/ previous owner and Lingenfelter light weight brackets and light weight glass bumpers (Sled City). Running the aluminum wheels (in storage, similar to Torq thrust D's) would be a few more lbs! The Crager's look nice but heavy....
Thank for the compliment!
Gary
