What's it Worth 68 coronet rt convertible
Bennoel 10
8:32 AM
Toronto
Wondering on what the membership thinks...
68 coronet rt convert is worth. Auto console. I believe original drivetrain. Has had a repaint and bodywork. Northern car all its life, meaning used as a car in the rust belt in its early years maybe not so much after a decade or so. Just guessing
Been off the road for a good while but runs, steers, stops and drives. Needs exhaust for sure. Top goes up and down with no issues. Lights work. All there that I could see on a first look.
I dunno, looks like a nice car in good colours though that could be driven as is.
For sure it could be driven as is after it's been given a mechanical inspection and necessary repairs completed. It has no exhaust at present other than head pipes. My concern is what's underneath ?. I did look at the underside and it's lathered with heavy grease. Appears to have been applied many many times over the years. I was allowed to scrape off some but understandably not extensively. Where scraped off looked good. Obviously in the corners and tight spots is my concern. It's what I can't see that concerns me. So with it being a convertible and low numbers and a running driving car, not a show piece and not a complete project where does the value fall ???
The top well is suspect and the Dutchman panel. If you look up inside the trunk hinges look for blisters and rot, the rest is normal stuff... what is it worth is all up to you!
Start at 50k and add for being a convertible and red and subtract the problems like paint and body and there you go... I like it.
I would think low side would be around $30K as it looks like you wouldn't have to go looking for missing parts?
If it runs and drives good, dosen't need the driveline and suspension rebuilt, then I could see it going for $40K?
Just my opinion, I haven't looked up prices in a long time, so I could be way off?
Can't tell condition of the rust and the rest of the car or how correct it is without inspecting it.
I don't know much about the '68 year. I though the head rests were for '69 and up?
Not sure on the radiator either.
1968 is least desirable of the breed. This will likely never be a high end car, but color combo is good. Beautifully restored driver is $60k at best. Working backwards if you paid in the neighborhood of $20-25k you might feel alright. You will likely be over invested in the long run, but driving a convertible has its perks.
When I first saw the ad, I was thinking around $30,000 would be right. There were always low production numbers of R/ T convertibles; likely less than a 1,000. At shows, I find the '68 R/T to be the least seen. Headrests were an option on 1968 R/T's, and became standard equipment after January 1, 1969. Although a 26" radiator was standard equipment on a 1967 R/T, it became an option in 1968 and later. So, it is not unusual to see a 22" radiator in these cars. The Charger-inspired Rallye dash was also an option. I own a 1967 R/T.
First, you have to establish it's a real Coronet R/T.
That’s exactly the first thing I thought of. Years ago when I was looking for a 68-70 b body convertible, I came across a small time dealer with a 68 RT …..except it wasn’t. When I mentioned to him that the vin didn’t start with WS ,he had that look on his face. You know the look…..busted.
He then said…..well that’s how I bought it!
HUH?
I'll echo the $25k feels ballpark with what we know about it. Pics of lower body and pans would firm up the guesses. Cool driver!
Can you get it up on jack stands (or a lift) and poke around with an Ice pick? Leave the grease but see if it's hiding the work of the dreaded tin worm...
BTW, why I'm :popcorn:
I would check really good where they spray bombed undercoating. 9 times out of 10 that was done to try to hide something.
I agree but there's so much it's almost ridiculous. On the trunk dropoffs it's so thick as if it was done for decades which I believe it was. Not fresh by any means.
I would say that super thick undercoating is factory. The shiny black stuff looks oily/wet. Maybe somebody sprayed something over the factory stuff to make it look better. If the thick stuff is factory, I have found on my 68 that it does a really good job of protection. Any of the places I have had to remove it haven't shown signs of decay underneath.
