What's it Worth 68 coronet rt convertible
To me that undercoating looks factory, later touched up. It could possibly be dead solid underneath it, or not. There is just no way of knowing without either removing it or if he'll let you, try to punch a screwdriver through in spots.
If I was looking at the car and the price was reasonable I would probably accept the risk as it looks pretty good. If the price was upper end to what I thought it should be I would insist on trying to punch a screwdriver through. Hopefully that makes sense.
Maybe I'm wrong and it's your money but I think I would be pretty excited about this car. I'd be driving it after glossing over the mechanical and enjoying cruising it without worrying about the minor cosmetic faults. On a car like this it just adds charactor. I appreciate a car that looks to be looked after over the decades and what you see is what you get. New paint and body quite often means you're buying about half of what came out the factory and about half replaced.
As mentioned, proceed with caution on undercoating, but this looks more precautionary than deceptive. Looks pretty clean and solid underneath, just heavily boogered.
Less is best on the entry price. Wheels and tires need replaced. The brakes, drivetrain, fuel system, cooling system will all need service. If you can turn your own wrenches, it's just time and part sourcing. Gets costly quickly through a competent shop. You already mentioned exhaust needs replaced. Interior is original so it tells the truth, but presents as such.
Are you going to make a move on it?
There were always low production numbers of R/ T convertibles; likely less than a 1,000. At shows, I find the '68 R/T to be the least seen. Headrests were an option on 1968 R/T's, and became standard equipment after January 1, 1969. Although a 26" radiator was standard equipment on a 1967 R/T, it became an option in 1968 and later. So, it is not unusual to see a 22" radiator in these cars. The Charger-inspired Rallye dash was also an option. I own a 1967 R/T.
There were fewer R/T convertibles made in four years (1,976) than there were 69 Road Runner convertibles made in one year (2,128). R/T convertibles are not common.
The 22" radiator was standard 68-70 meaning most this is what most R/Ts had. Ordering a/c, trailer towing or an axle pacage that increased cooling demand got you the 26" radiator. A 26" radiator was not something that was a stand alone option.
In terms of desirability, I don't believe the '68 is the least desirable. While most plentiful, I think the '67 is the least 'desirable', and I do not like using that term, due to the squared off styling. The polarizing front end of the '70 drives down demand, or the number of people looking to buy one, but the scarcity ups the price as so few examples come up for sale. The styling of the '68 with the delta tail light ups buyer interest. I prefer the styling of the '69 due to the front grill.
I own a '69 R/T convertible.
It appears to be a relatively solid and complete driver quality car. I think contingent on several things already mentioned, I don't think 40K plus or minus is out of the realm.
Looks like one of the many different anti rust coatings they used over there like ziebart etc.. oily,greasy, waxy, stuff. I've seen many different kinds from Ontario. Check for rubber plugs in the door jambs
It looks like the factory undercoating to me also. It does look to be a heavier coating though. Maybe it was done Monday morning and the applier was hung over and moving slow.
It's a weird thing. Desirable. Desirable to who exactly? More people bought mustangs.. do we care what a mustang owner finds Desirable?
To someone who wants a 68 Coronet, that's the most Desirable car..
There was a '68 GTX from central PA, bought and flipped on this site a few years back. Original factory undercoating, plus Ziebert when new. Looked like the Coronet in this thread underneath, with even more gloop. I checked the car out when it was in the car corral at Carlisle, before the flipper bought it. Perfect original metal, held a kitchen magnet the whole way around. If I'd had storage space, I'd have grabbed it in a heartbeat, was priced at $32,500.
I agree. I don't think the term 'desirable' was necessarily appropriate. I was echoing the term from a previous post. It reflects strength of personal choice.
I think the market tells us that between two comparably equipped '67 and 68s' the '68's will sell for more. That may not equal desirability.
When the comment about no exhaust was made I expected rotten remains to be hanging under the car... The pipes being cut away and what remains appears reasonably solid makes me feel better about what is there...
I half expected to see the edges of the holes in the frame to be eaten thin, salty crud enters through those low hanging openings and eats the metal from the inside... What I see is actually pretty promising...
I'd still feel better if I could poke at it but it doesn't look nearly as bad as some cars I've seen, cars that people have spent big $$$$ on...
I would like to make an offer but the problem is as common as they come. They, the seller have grandiose expections. They believe it's worth $80,000. I asked if there were any offers ? Apparently somebody offered $65,000 . This is Canadian money but still very optimistic. I asked if they had the individuals number who gave the offer and suggested they take it as I was nowhere close. That was last summer and I believe it's still there. Thinking of revisiting.
Thanks again for all input. Much appreciated
As said before,get in the trunk,up under the dutchman,and down where the water lays. Also,I'd put a floor jack under it on the frame rails,if it wants to break in half when you jack it,run away.
I think you're on your game, your thinking is exactly how I would be approaching it as well. The trouble with sellers is that they sometimes have an emotional attachment. However sometimes if you have stayed in contact for a year or two they will consider selling to you because of your continued interest. Good luck with it.
I suppose it could be a $100k car restored perfectly but it will take $80k to get it there. They probably know that and that is why they haven't done it. Perhaps they would like to see someone go through it and get it on the road again, then again maybe they don't care.
Thanks again to all. Much appreciated. Car is in storage for the next few months so we'll see. I'll keep ya in the loop.
Shoot your shot. Pick a number and don't budge.
This is what I did with the GTX I currently own. I offered that number in 2019, and the owner didn't budge. He was not actively looking to sell the car at the time, and I offered him a premium over market, based on the car's condition, and unique history. Three years later, he made the next move, giving me right of first refusal. I spent three hours inspecting the car in every area, then test drove it. After three months of negotiation, I bought it for what I had offered three years earlier. Got $5000 worth of parts as well.
I was prepared to walk away, even though I had been pursuing the car in question for five decades. I pushed that point hard with the seller, emphasizing that I already had a numbers matching Hemi car that would have to go if I did the deal.
Just came across this post. Status update?
From your location, I'm guessing you are in Ontario. Is the car a Canadian car? Any paperwork with it? Are you looknig for a value in Cdn or USD?
Mine was sold new in Saskatoon, SK. Not the first place you think of when you think about big block convertibles!
You are correct I'm located in the city of Toronto. Car is always been an Ontario car and originally used as a car but at some point was retired to occasional use. Can't recall the mileage but under 100k. 80 ish ?? Not much if any paperwork just the usual stories. Yeah just curious as what the membership thinks. Me I was thinking $30 k Canadian funds. Like all of them it's only the start and they all need lots of money.
Wondering on what the membership thinks...
68 coronet rt convert is worth. Auto console. I believe original drivetrain. Has had a repaint and bodywork. Northern car all its life, meaning used as a car in the rust belt in its early years maybe not so much after a decade or so. Just guessing
Been off the road for a good while but runs, steers, stops and drives. Needs exhaust for sure. Top goes up and down with no issues. Lights work. All there that I could see on a first look.
Hi there. Any news on the RT? The thread is getting old, but convertible season is around the corner (more or less) here in Southern Ontario....! Is it listed for sale anywhere? Is there a fender tag?
No fender tag if my memory serves me correct ?
It's not listed to my knowledge, just word of mouth. Still for sale as of last month.
