TREMEC SHIFTER RELOCATION FOR 68 B BODY
2:36 PM
Newmarket
I am about to start the conversion from 727 to a TKO 5 speed. I bought a complete trans, bellhousing, clutch and all the parts from a 68 coronet that was being converted to a modern Hemi swap.
The shifter location out of the floor is quite far forward, i am wondering if anyone in this forum has made a shifter relocation to shorten the throw. Also it would remove the offset bracket between the top of the trans and the shifter.
the photo below is an example of what i am thinking about.
Lol good assessment
Here is where my tower is located and a picture of it in the car. I have the console and pistol grip. There are many options for shifter towers and shift handles. I would deal with that once I got it in the car with the seat in place.
I think you can move the shifter (you can on the TKX). Also there are a number of aftermarket companies that make different types of shifters that might be helpful.
The pics show where the shifter on my TKX is located. I ordered it that way from American Powertrain, so I have no idea what might be involved in moving the shifter location.
I ended up cutting the crossmember to gain more clearance. I did not have enough room to get my driveline angles correct. I used this upper hoop along with the transmission mount from Holley.
I'm sure the TKO has multiple shifter positions - look on internet or ring Tremec.
Changing location of the shifter is fairly straightforward on the TKX - I imagine the TKO is similar. You should be able to get it close to or the same as the factory location.
I have a TKX in mine.
I agree with getting the trans and seats in first. I have tried to search for b body cars with this type of set up. I have not had any luck finding anything.
Looks like i have the same Keisler and TKO 5 spd set up that you have ... (minus the Hemi..LOL) have you had good luck with this transmission over the years? have you made any changes to the shifter springs?
This Conglom ended up being happily close. Easy Rowing. Second gear pictured.
