Would this shifter fit?
Seems to me that Sox and Martin did extremely well with an Inland. If it was good enough for them, I guess I will use ours. I will keep the Hurst shifter that was in the car when we bought it.
I'm pretty sure that Ronnie made a living stirring a Hurst. That Inland would be one of the first things to go.
That handle will plug into a '68 bayonet-style mechanism but might hit the dash in first and third. The '70 mechanism had a shorter throw.
"Inland" was the supplier of 4-speed shifter mechanisms to Chrysler from 1966-early1968. Characterized by tubular shifter with T-handle to access Reverse. Black knob with shift pattern. They must have been cheaper than a Hurst, and did not work as well. I built a 1967 Coronet with a 4-speed, and adapted an Inland shifter handle to a set of Hurst guts, to make it look correct for the year of production. I am not good at grabbing pictures and posting them, so will leave this to someone else.
Apparently there's an adapter for this these days:
SHIFTER MECHANISM HURST/INLAND CONVERSION - Mopar A833 4-Speed Transmission & Component Specialists
This is the stick I put in my 68 Charger, it clears and feels great on the A855 5 speed. It was $260 when I bought it, 395 is outrageous!
Shifter handle or stick. The "shifter" is the mechanism.
