64 Polara Manual Steering box
Terry1213
7:06 PM
SoCal Mojave Desert
I want to swap to a 24:1 stock-style manual steering box. Has anyone done this?? What brand, company, and part number for the manual box? Thanks
I know there's a length difference between the two steering shafts, not sure which way ? I'm sure someone will verify that. I have seen an adapter, to go from short to longer, but sorry, I don't have the info or part # available...
Manual boxes on B Bodies were the same from 62-72...
You will need to find a manual column as the steering shaft itself is one piece and needs to be about 3" longer...
The part referenced above will work for that...It's just a half assed way to do it...
I decided to stay with the power. Got a box with Modern Feel from Steer and Gear in Ohio. Rebuilt the coupler, installed their box and it's fine now. Straight as an arrow. I also figured I would try their coupler boot. So far so good.
