WTB WTB 1966 Dodge Charger interior door panel aluminum trim.
northeastmoparnet
8:30 AM
boston
Looking for a drivers side aluminum wide panel that is attached to the door panel under the armrest. If it matters this is a non a/c car. Please send me a picture as I am looking for straight/clean parts. I would also entertain buying a pair for both doors if need be. This is for a 1966 Dodge Charger.....MANUAL WINDOWS
Manual windows I assume?
How soon are you in need? Need also the molding around it?
Thank You.. Yes, Manual windows. I stupidly put non A/C car for all those who wish to laugh....
All I needed was the brushed aluminum insert I have all the rest of the trim. Mine was bad and I tried to clean itbut I made it worse. I tried to wire brush it with my eastwood tool and I screwed it bad. So, I am looking for a good one and I will just clean the other side as best I can. or I was thinking on sanding them both and spraying them with light agent silver to match the upper door charger trim next to the vent window. But I like the aluminum which is brushed effect.
Bummer. I have a couple cars at a farm that I have been taking parts off but under snow right now. Will be able to get what you need in about a month or so. They are also about 100 miles away too.
Thats ok. I was also going to lok around for a self stick inlay material of brushed aluminum and maybe stick it on top of mine. So the search goes on. Stay warm...Thanks
Make sure you have a correct Charger window regulator. Crank stem/shaft is longer than a Satellite/Coronet.
Charger stem is 1”.
OK Can u send me a price and photo when you return? Thank You
