IRONHRS
Hello,
I just started working on my dad's 1966 Charger.
I am in the process of replacing the front inner/ outer bearings AND Grease Caps.
The driver side has a 10" drum brake hub (Grease Cap is missing which lead to failure). The passenger side has an 11" drum brake hub (Grease cap in good shape).
1. Can you please verify that the inner/outer bearing part numbers are the same? Looking on RockAuto they appear to be the same.
2. Would you please tell me why the grease cap ON the 11" hub is too small for the 10" hub (the 10" hub in this picture has an ID Inside Diameter that is larger than the 11")?
3. Why is the inside lip of the 10" hub machined out (see blue arrow)? It is not solid like the 11" (thus, the Grease cap won't fit the 10")? Does it require a different Grease Cap?
Because this car did not have a grease cap on the 10" side, the bearings failed. I would like to replace the grease caps but when i look it up it says the grease caps are interchangeable.
I sure would appreciate any insight you can provide.
Regards,
Hank
Regards,
Hank
