505 build Dyno numbers
Buillding a similar engine right now. Motor home 440 block, 4.350x4.500, Trick Flow 240's, 235/241 564/572 112 from Dwayne, 6 pac intake and carbs, 10.5-1, 727, 3.54 Dana. Going in a friends V code Challenger.
Thats the plan. He has plenty of racecars so this one is all street This will be his wifes. It has Caltracs as well.
Torquey big blocks must be in style around here...I also ordered a hydraulic roller from Dwayne...238/244 @ .050, .581/.577 lift but with a 112 LSA for better vacuum. 440/495, 9.8 to 1, Edelbrock heads lightly ported, RPM intake, 2" headers. Dwayne thinks mine will peak around 5500, the OPs peaked at 5400 with 10 more cubes, a bigger cam and better heads so mine may peak earlier than we thought.
I'm excited though....Having more torque down low compared to the huge solid lifter cam I have now...that will make for a much better street car.
Your 112* may widen the curve a little. I was a little surprised mine peaked so early. Although at 5900 I was only down 14hp.
one takeaway I got from Andy F’s book is that the more cubes, the lower the rpm hp will peak with the same components. If I got it right.
It would be interesting to see the graph at and beyond peak HP. If it falls off a cliff, that isn't good but if the drop off is gradual, that is fantastic.
I'll bet you're right on that. It makes sense with the same reasoning that a cam that is choppy in a 383 may be mild in a 505.
