Rebelrouser
The biggest bangs for the buck are gears and a torque converter in combination and working together. Never used the cam you mention but if it is a stock short block you have probably low compression. Easy way to tell if you need more compression with that cam is to do a simple cranking compression test, that will give you an idea of what the dynamic compression is. If you do a cranking compression test and you have less than about 140 lbs you need more compression to make it run right. Also a cheap way to increase the dynamic compression is to advance the cam timing, a timing chain set with multiple keyways is a pretty cheap investment. For what is possible out of a low compression engine look at what NHRA stock eliminator cars do with a stock low compression short block. Stock index for a car like yours is low 11's and most competitive racers run 4 tenths under the index.
