BSB67
If he's already got 2293s (original post said TRW domed piston) and he wants it to run on pump gas with that smallish cam..... op better do some calculatin' to figure out what compression ratio he wants. That will determine which heads to look at.
My suggestion would be the open chamber rpms.
(I have 2295s domed trws in a 440 with iron heads, and it will run on 91, but it has 40 more degrees of cam than the op, and lots of converter and gear, and I still add a bit of 100LL cause I can).
Yep. The details will matter
