- 11:24 PM
- Sep 5, 2022
- Mülheim an der Ruhr, Germany
Hi FBBO,
I’m planning to convert my ’64 Polara from manual to power steering.
I already have the correct gearbox and oil pump. I’ve read that the steering column main shaft for power steering is shorter than the one for manual steering. Is that true? What are the dimensions to search one?
Alternatively, can I modify the existing shaft by cutting it and using an adapter?
Also, is the pitman arm the same for both setups, or do I need a different one for power steering?
Thanks in advance for your help.
