73 Charger hard top window felts #
JasonD
12:37 AM
NE TN
Looking for the right window felt part number for a 73 Charger with roll down quarter windows. Looking for inners and outlets for all 4 windows.
What does it mean by with or without plastic felts? Looks like PUI is still backordered. Who else makes them? OEM matching isn’t important.
When purchasing the window felts, the Top Catwhiskers, are the preferred choice. The Top Catwhiskers are the most correct in application, fitment and application on the market. We have been making and providing these to the restoration hobby for over 30 years.
For the 73 to 74 Chargers, the options are the SE variety and the standard Charger. The difference being the "opera windows" for the SE's.
We offer the SE's in either a shiny bright bead or a black bead. The SE's are offered in a four piece outer set or a ten piece outer and inner kit. The same holds true for the regular Charger. It will be available as either a four piece outers only kit or ten piece inners and outers. Again, offered in either the bright stainless bead or the black rubber coated bead. If your inners are in good shape, you might want to consider just replacing the outers as the inners can be a pain attaching them.
We are currently three to four weeks out in getting these back in stock for our vendors. We have a wide range of vendors, so you might find someone with a set in inventory. Suggested retail is $195.00 for a ten piece set.
Jason,
I have these. New Top Cat for Qtr. windows. I may have a set for front doors. Let me know.
Jason,
