D1esel
- 4:34 AM
- Mar 11, 2025
- Parksville,British Columbia,Canada
I want to install a vinyl top on my 67 coronet. I have 2 options. Padded or non padded. Which should I order
Agree. Non-padded on my 67 Coronet. It had a padded one on it when I got it. But not the same padding as a 78.........Non padded.. check out a 78 new Yorker if you're wondering what padded is all about
I have padded on mine. Simply because I did not know there was a difference. I bought from a member here long ago. He probably didn’t want it! There is no problem with the fit. Longevity? Not sure.
Correct.So,originally it was non padded?
Yup. That's what mine looked like.
That is what I have always seen. What is that vinyl pattern and is rhat called padded?
My concern with padded would be over time outer vinyl may crack and let moisture in. Your roof is painted I assume so your not like factory, no paint. No padding MO.
