Small block to big block question
68rrdream
2:28 AM
Miami, fl
I already read a sticky here telling most of the swap. I currently have 318/727 in a 67 belvedere.
While searching for parts to play with the 318 I found a good used 383/727 out of a 68 charger.
I know I need the mounts, extend dist wiring, radiator, etc.
What about suspension? Will I need to change torsion bars?
Will I need a driveshaft?
Most 318's got 904 transmissions... If it's really a 727 the driveshaft will work... But the transmission won't... Torsion bars will work but bigger is better...
Well it has the big hump on the passanger side of the pan so from what I've seen that is a 727. I also read somewhere that the 66-67 b bodies all came 727.
For Radiator look at ECP... I got mine from them and it has been money well spent which is not something i say often :)
(just guessing that you have a 22" opening)
Read your other thread on a 383 swap
