- 1:30 PM
- Jul 17, 2008
- Southeastern, PA
Sold a few years back
What was the issue? Wasn't backwards like the last oneAnother tail stripe installed wrong.
What was the issue? Wasn't backwards like the last one View attachment 1824919
RC, I see the issue with the yellow car, but the silver and red car stripes look similar in the slight wedge between the stripe and the bumper cutout. What are the differences in the two?The stripe goes straight down the quarters instead of not quite following the angle of the bumper indentation. You can see it briefly in their walk around video.
Correct ....
Both of these are incorrect ...
Also, isn't the side marker supposed to be centered in the measurement of the thick and thin stripe together, not just centered in the large stripe, correct? Meaning that the marker should be slightly offset rearward in the thick stripe...
When I installed my stripe back in '93 I used the centerfold sales brochure Pic as a guide. It looks like it's very close to parallel with the bumper recess.
You even put them in the garage in order.68, 69 & 70 in my garage. The 69 belongs to a friend.
The 69 SHOULD belong to you so you have all 368, 69 & 70 in my garage. The 69 belongs to a friend.
The 69 SHOULD belong to you so you have all 3![]()
Add a white stripe to that and it would be perfect
If you could remember how the factory did it you wouldn’t be complainingIf you could see the other side, I bet that it would not be a mirror image.
I’m Just pointing out a fact too, highly doubt 2 cars had the stripe in the same spot like “oe resto” guys beg forHere's the original stripe on my '68. No complaint, just pointing out a fact.
