- 12:20 AM
- Feb 20, 2012
- New Hampster
Need a low horn in good working condition.
Thanks.
Thanks.
Just a thought...
Have you put the horn in a vice and remove the adjustment screw tap the horn with a hammer then re-instal the screw and then adjust while
having it hooked up to 12v supply?
I have done this with a couple horns
The low horn Posted above works. Tested it today. Not sure if that is what you want.
Thanks. Jim
How did you bench test itThe low horn Posted above works. Tested it today. Not sure if that is what you want.
Thanks. Jim
Set the horn on my negative terminal on my powerstroke truck. Ran a wire from horn and touched positive terminal. And horn went beep, did it like 6 times.How did you bench test it
Thank youSet the horn on my negative terminal on my powerstroke truck. Ran a wire from horn and touched positive terminal. And horn went beep, did it like 6 times.
I also posted it on exterior parts for sale.
