icetech
The ignitor ii goes right in a factory dist and is like $160....Thanks! I don’t have an Amazon account but know a few that do. I’ll have to check on the distributor… $427 at Summit.
I’ll probably go for a new distributor as it’s the original and the car has 120,000 miles on it. I will shop around though. Thanks!
Other option is have @HALIFAXHOPS setup a dist for you.... that's all he does and seems to live forI’ll probably go for a new distributor as it’s the original and the car has 120,000 miles on it. I will shop around though. Thanks!
Other option is have @HALIFAXHOPS setup a dist for you.... that's all he does and seems to live forHe setup mine and sold it to me...
I've used the Pertronics kits on my 68 426 Hemi and on my current 67 Satellite 383. Easy to install, and looks fairly stock. To keep the original look, I soldered a wire into the back of the firewall resistor, so you can leave it where it is. It's not required on the Pertronics system. Some models of the Pertronics kits also have a built in rev limiter.What’s the newest? What are you guys using recently?
I’ve done a few 70’s type external 5 pin (4 on the later) conversions. And while they work good, it’s a lot of wiring and installation work. Are the HEI kits any good? Thanks!
That's a nice looking engine bay RunnerThe coolest thing about the Pertronix units is that they look relatively stock.
NO !!???Oh good we are talking about ignition again. The sun came out today so went for a drive and my HEI module died. I have 1100 miles on the car and this is the fourth module I have put in it.
