Power steering pumps
Timmayy
12:01 AM
Tiverton RI
Since our parts are slowly getter harder to come by, I am wondering if the different types of PS pumps are interchangeable as long as you use the correct brackets. Will they line up with the belts? Are they all compatible with the steering boxes? Big block and small block the same with the proper brackets? Do the pulley diameters make a big difference? Just wondering. I tried to search for this topic but didn't see it.
Not an expert but the different pumps, Federal, TRW//Thompson, Saginaw should all work with the PS box as far as I know. With the proper bracket on the engine it should line up OK with the other pulleys, provided they too are correct for the engine. Pumps with pressed on pulleys can have the pulleys adjusted slightly on the shaft although to press the pulley on the shaft further would require disassembly of the pump. A pulley puller can pull it out slightly if set too deep. Early pumps/boxes (through 1966) use a 5/8” return hose. Pumps and boxes after that used a small hose (1/2”?). This has to be coordinated although the return valve/hose nipple on the box is a separate piece and may be interchangeable - not sure on that. Also, there are 3 different angle return valve/hose nipples available - 0 degrees, 45 degrees, and 90 degrees. Not sure which goes with what but my 440 GTX has a 45 degree one and my 66 Hemi has a 90 degree one to clear the exhaust manifold.
About all I know, or think I know.
Thank you. I may try to convert all my cars to the newer Saginaw type. I believe they are 1969 and up?
I think I mis-spoke above about being able to re-set the pulley on all the pumps. I believe pulleys are secured on Federal pumps with a bolt. Not sure about Saginaw. Both of my cars have TRW pumps.
Do or are you having a PS pump problem??.....or is this just a fishing / future reference exercise? Consult your FSM and PARTS MANUALS for interchangeably......most PS pumps are specific to vehicle, engine, hose routing, brackets, sheave arrangement, belt circumference......there is no one size fits all application........just my opinion......
BOB RENTON
BOB RENTON
No fishing. I sent out my ps pump to be rebuilt last week.
On my ‘68 383 with A/C, the federal pump was always problematic. Between the leaks and the low pressure problems at idle, I pulled it every few years for rework. I found that a Saginaw with brackets off a ‘69 383 charger with a/c was a direct bolt-on but needed a slightly longer belt. I never had a single problem with it for years. Much better set up. If being numbers correct is not an issue, I’d run the Saginaw, just try to find one off a motor configuration similar to what you have.
I know Saginaw pumps are regarded as being better.
But I still have the original Federal pump in my Charger and it works just fine.
Almost 133,000 miles on it now.
(Hopefully it doesn't start leaking now...)
If it’s running good, I wouldn’t mess with it. I think you can still get seal kits off of rock auto when you need it. I was lucky enough to find a nos pump unit for my federal pump. I’ll be running that on my Bee. But my ‘67 GTX clone will get the Saginaw for sure.
