- 12:54 PM
- Aug 18, 2024
- Virginia Chesapeake Bay
Okay I found this thread and so actually the PCV does go on drivers side and breather on passenger side.  Now the only question I have is can I T the vacuum hose for the snorkel butterfly valves to the PCV line hooked to the carb, and will there be enough vacuum to operate both?  Any help would be appreciated.
							 www.forbbodiesonly.com
				1972 Dodge Charger SE 440 HP questions on Factory Valve cover breathers etc!!
Ok,I'm finally getting the engine back together in the car and I am trying to understand how to set up the factory breather(s), PVC etc. Enclosed are pictures showing the valve covers and holes I need plugged.  To complicate things a bit I have the non-factory six-pack setup on the car. Also...
