Ignition wiring help needed
DynamicXX
3:23 PM
Corbyville, Ontario, CA
Quick rundown on what I have/have done:
1969 Coronet with 1970 383. Car came with Blaster 2 Coil and Distributer.
Old wiring harness was a cobbled mess. I've replaced it, under dash harness, wiper motor harness etc.
Purchased a engine wiring harness, which I cannot return, it is for a BB w/ECU, as I don't have point's I thought it would work. Didn't see the 5-wire/ECU plug when I ordered...
Now for the question, I don't have an ECU? So can I adapt the new wiring harness for the ignition that I have now?
I have the wiring diagram printed and am using.
It appears you have a "ready to run distributor".
It just needs 12Volts and then it will pulse the coil - terminal.
I know it shows chevy but the wiring between the distributor and coil is always the same.
*Do you have the 3 pin plug and wires for the coil?
Looks like you substituted 2 individual ballast resistors, neither of which you would use for this setup.
You just need to run a wire from the terminal with blue and brown which are on one of your ballast resistors to the Coil +.
This wire will have power during start and run positions.
Note gray wire goes to tach.
More pictures of the car can be accepted as payment here...
Thank you.
Previous owner had both Ballast Resistors connected, so you are saying I do not need to use those? One ballast resistor plugs into the Washer Motor harness...
Yes, the coil has the 3-pin plug.
So, do I still use the ballast resistor's, x2, and what do I do with the pigtail for the ECU ?
You can make a jumper with male spade terminals to replace the lower left ballast resistor.
Test for spark in crank and start positions.
Then if you like you can get the resistor and put a solid wire inside.
